I WAS USING VIRTUAL DJ 5 AND USING THE SKIP BEAT, BUT NOW I HAVE 6 AND IT'S GONE. I KEEP HEARING PEOPLE TALKING ABOUT SEEK, GOTO, BUT I CAN'T FIND THEM.
ANY IDEA'S.
THANK'S
ANY IDEA'S.
THANK'S
Posted Fri 11 Jun 10 @ 12:34 pm
I think that you need to provide more detail. What do you mean by "skip beat" exactly? What button on the interface were you referring to? The transport buttons << and >> skip 16 beats, for example. I'm sure someone will chime in once you've explained clearly what you are trying to accomplish ;)
Also, please don't write your posts in CAPS, it indicates SHOUTING in forums.
Posted Fri 11 Jun 10 @ 2:40 pm
To skip back/forward by a number of beats, use goto, e.g:
goto +1 will go forwards by 1 beat.
goto -1 will go back by 1 beat.
Posted Fri 11 Jun 10 @ 3:33 pm
discjockeydoc
what i mean is this. i was using the skip beat fuction for chopping and screwing my music, but now it's gone. i looked on here and saw people saying use seek or goto, but when i go to mappers i can't find anything called seek and i can only see goto_cue 1 - 10.
sorry if it seems i'm being stupid.
jpboggis
where will i find the goto + 1.
THANKS
jpboggis
THANKS
Posted Sat 12 Jun 10 @ 5:57 am
You must map keys to these actions.
By default, CTRL + left/right arrow key is mapped to goto -1/+1 and CTRL+ SHIFT + left/rigth arrow key is mapped to goto -4/+4.
To map/change mappings:
For further information, please see:
https://virtualdj.com/wiki/VDJScript%20Examples.html
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/VDJscript_verbs.html
- Go to CONFIG -> Mappers
- Choose the appropriate device from the drop-down list, e.g: Keyboard, Hercules DJ Console, etc. or Simple MIDI Wrapper for a MIDI capable controller that does not have built-in (Native) support.
- Click the + (Add) button, then press the key/button or move the knob/slider that you wish to map.
- Type an appropriate action in the Action: box, e.g: goto -1
Posted Sat 12 Jun 10 @ 1:17 pm
THANK YOU SO MUCH.
Posted Sun 13 Jun 10 @ 4:22 am
ok im having the same problem i go to my configurations/mapers click on keyboard then create new key then i type ctrl+left arrow and in action i type goto-1 and it doesnt work am i doing it right
Posted Sun 09 Jun 13 @ 6:25 pm
There needs to be a space between goto and -1
Posted Mon 10 Jun 13 @ 11:48 am
@jpbogis you are the best in this thing.... i looked for this action for years... thanks a lot.
Posted Mon 09 Oct 17 @ 1:13 pm
