Forum: Old versions
Topic: mapping help
can anyone tell me what the string would be, im stuck. I want to be able to open the effects drop down box and slect an effect from the playing deck. i can only get deck 1 to do this. can anyone help me out on this. Thanks
Posted Sat 22 May 10 @ 8:45 am
For deck 1 type "deck 1 effect select" and for deck 2 type "deck 2 effect select". Depending on which deck you want always add "deck 1" or "deck 2". You can also look here, https://virtualdj.com/wiki/VDJscript_verbs.html Hope this helps.
Huey
