Hello, i am having an issue with the program skipping and cutting out after a few hours use, and am not sure what to do, now im not gonna lie i am using a"real" version if u get my drift, could this be why, and if not, what can i do to fix this issue.....please help!!..
Posted Mon 17 May 10 @ 6:48 pm
I'm not going to lie either ;-)
"Tech Support" from your fellow VDJ users seems to be a lot faster and forthcoming between registered users. (IE: some registered users only help other registered users)
the "Teamers" (the 'official' tech support guys) will help anyone.. but theirs only so many of them..
Posted Mon 17 May 10 @ 9:59 pm
I wouldn't go so far as to say that...I made a post in this very forum on May 13 and up to today have had 60 views and not 1 reply. I got a faster reply sending in a ticket to Support.
The OP should send a ticket to Support for "official" help.
Posted Tue 18 May 10 @ 3:16 pm
Skipping, stuttering, etc. is usually caused by performace issues with your computer. If this occurs after a few hours then it might be an overheating issue, e.g: Failed cooling fan, blocked cooling vents, or inadequate ventilation (A DJ laptop stand will help.)
If you are using an illegal version then this will not help either. If this is the case, please support the software and its future development by purchasing it: https://virtualdj.com/buy/
Please see the following for some tips on resolving common causes of performance issues:
https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
Posted Tue 18 May 10 @ 5:48 pm
