hi i am having troble setting up my audio4 dj,my issue is im not sure how to connect the rca to the soundcard and the mixer to run my timecode vinyl the audio8 was quiet easy to figure out but way to expensive so can some one help me!! lol im using the pioneer djm-300 and stanton t.62 decks thank you! B3@TZ
Posted Tue 11 May 10 @ 9:02 am
Hello I don't think this is more harder to plug than a Audio 8 is. So just connect your timecode players to the sound card inputs and the sound card outputs to the mixer LINE IN. that's it.
To setup timecodes correctly you may need to read this:
https://virtualdj.com/wiki/TimeCode%20Config.html
Posted Tue 11 May 10 @ 9:42 am
Exactly as acw_dj said. I own it and its a breeze. Install the drivers,conect the outputs of the turntables to the inputs 1/2 (audio 4) marked behind for the first Turntable and inputs 3/4 for the second turntable. Connect outputs 1/2 on the audio 4 to the first channel of the mixer then outputs 3/4 for the second channel of the mixer. Go to options in vdj in sound setup select under inputs timecodes,under outputs external mixer and soundcard asio. Click on debug to raise the input signal of the mixer if the signal is not strong enough. Simple.
Posted Tue 11 May 10 @ 1:03 pm
