Alright guys, so here's my pickle.
I used 5.2.1 for the longest. However after updating my Hercules drivers, however... the RMX no longer worked with it. So I upgraded. Now everything feels out of whack. My faders and jogwheels feel far less sensitive. And I can't go back to a previous version of the driver, so I can't go back to 5.2.1.
So here's my questions...
1) How can I get my older version of the drivers back?
2) If #1 isn't possible, how can I make my faders and jogwheels more sensitive?
3) Also having trouble with my tags going from 5.2.1 to 6.0.8. My cue points, my Gain settings, etc. have disappeared from VDJ. Any good way to get these back, or my going to have to go through my tracks again, one-by-one, and re-cue them? Because that's a pain in the butt, and will really tick me off if that's the case.
Posted Sun 09 May 10 @ 11:19 pm
VDJ 5.2.1 + driver v2.09 under Snow Leopard should normally still work ... at least it does on both my Imac and Mac Mini.
Did you try reinstalling VDJ, then the driver?
As for VDJ 6, it uses a completely different way to handle the controllers. More flexible but much more complicated to configure (specially if like me you don't like scripting....)
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/VDJScript%20Examples.html
For the database, V6 also has it's own, so I'm not sure if there is a way to import old settings...
Posted Tue 11 May 10 @ 8:07 am
Haven't tried that yet; will do now.
Edit:
You are a freakin' genius.
Posted Tue 11 May 10 @ 3:30 pm
