Forum: Old versions
Topic: VDJ V5 Karaoke problem
Right first off once I have enlarged the VDJ video screen to fit my secondary monitor (karaoke TV) the load up of karaoke tracks, Video & Song tracks slows down by allot, I am using Windows XP and a HP Pavilion dv1000 lap top.
Any idea on how to make it load faster? It does load fine when I am doing disco's therefore not using the video screen.
Secondly, I prefer to use Show Presenter for Karaoke side of things and VDJ for just music, But the secondary monitor flickers when I minimise VDJ to use Show presenter and also when I maximise it again, A friend suggested keeping VDJ on Restore Down (the button between minimise and close) but the button doesn’t work.
Any ideas to resolve the problems? Thanks, Richard
Posted Sun 09 May 10 @ 4:40 pm
disable video when using "show presenter"
What specification is the laptop? The recommended specification can be found on the following page: https://virtualdj.com/products/virtualdj/
There is a 'SpeedLoad' setting that will automatically slow down the loading of songs where playback performance might be impacted on a slower computer (I.e: You'd get stuttering due to over CPU utilisation.)
This setting can be changed using the Registry Tool https://virtualdj.com/addons/2170/Registry_Tool.html - However, this may have an adverse effect on a computer that is not fast enough.
NOTE: The tool is only available to registered licensed users. Please register your serial number on the following page to be able to download it https://virtualdj.com/users/edit.html
Assuming that you are using VirtualDJ Pro, you should ideally run video full-screen rather than maximising the window - Go to CONFIG -> Video and choose your external video output in the drop-down list. NOTE: The trial and limited editions of the software cannot do full-screen video and karaoke.
