Hello just got your trial all setup as well as the drivers for my fast track pro, I am trying to setup my 2 numark tables and gemni 4 chan mixer to work with time code. I have exausted my search ability (I think) to no avail ie your site, google, youtube etc but I am not having any luck. can someone please assist me or point me in the right direction?
thnx in advance
tyler
thnx in advance
tyler
Posted Sat 24 Apr 10 @ 12:15 pm
I am curious if it may be my cables I have my turntables (rca) going into 1/4' inch converters then into the ports on the front of the FTP 1 & 2 in this first screen grab both the "mono" inputs are checked off https://virtualdj.com/homepage/cioce/blogs/3092/_ENG__M-Audio_Fast_Track_PRO_and_Virtual_DJ_setup.html I seem to be getting some sort of signal when i go through the setup but it only seems to be on 1 side of the 2 time code boxes that show up on the config even tho it is at 100%
Posted Sat 24 Apr 10 @ 12:38 pm
well im starting to loose hope the further I dig into this issue, and I may have to cut my losses on what I have that is already non refundable. This post does not look good - https://virtualdj.com/forums/100323/PC_Version_Technical_Support/How_to_control_Virtual_DJ_using_FAST_TRACK_PRO_.html
Posted Sat 24 Apr 10 @ 1:46 pm
Check in there,
Fast track Pro has not enough channels fro correct timecode operation.
Posted Sun 25 Apr 10 @ 11:49 am
