I'm using a Lenovo T-61p Laptop. OS is XP. The Processor is a 2.2GHz Intel Core 2 Duo T7500 and the Memory is 2GB x 1 RAM (PC5300, 667 MHz, DDR2 SDRAM) . The discreet video card is 256MB. The DJ software is VDJ 6.08
The issue I\'m having is that the only video out option on the Lappy is the VGA Out port. The club at which I\'m planning to work is a s-video in. The Lenovo Tech I s/w said all I need to do is purchase a VGA to TV Composite adapter/cable (allegedly available at Radio Shack). I\'m not sure the tech understood all the nuances of the issue.
I would appreciate the thoughts & recommendations of all in the know who would like to contribute.
Thanx-in-advance Fellas!
Posted Tue 20 Apr 10 @ 10:48 am
Check out this thread https://virtualdj.com/forums/126035/General_Discussion/Video_Starter_Kit.html
This is a generic VGA to S-Video/Composite converter that I know is available stateside as one of the other posters in the thread from the US said he has been using one for years...
I've been using mine now for over a month and the picture quality is great.
Cheers,
Roy
Cheers,
Roy
Posted Tue 20 Apr 10 @ 11:23 am
OK, this seems to be the answer. The guys here who also only have a VGA out from their lappys rave about the picture quality.
Thanx all!!! Cheers, -Z-
http://www.newegg.com/Product/Produc...82E16815158142
Posted Tue 20 Apr 10 @ 12:07 pm
try one of these...
http://grandtec.com/products/video/xppro.html
or
http://grandtec.com/products/video/untimateEZ.html
both work great..... on XP though.... If you use windows 7 i don't know.....
or
Posted Thu 29 Apr 10 @ 8:45 am
