Hi,
I've been trying to figure out how I can go about djing from my computer using an embeded player such as windows media player and embedding it onto a website using also my own IP address and port #. Can anyone help me out with this problem? Thanks.
Posted Wed 14 Apr 10 @ 5:19 pm
You wanna broadcast??
Posted Wed 14 Apr 10 @ 9:14 pm
check out the radio forum, plenty of help, advice and tips there.
Posted Thu 15 Apr 10 @ 6:11 am
how do i crack the trial version code.
Posted Fri 16 Apr 10 @ 8:59 pm
by buying the program
Posted Sat 17 Apr 10 @ 3:00 am
@dj snagga, actually it's an easy process to do, firstly you must place your gig machine on a sturdy work surface, preferably a work bench is best I find, if you haven't got the following tools you can hire them from a local "tool" company, firstly take a 3lb hammer and smash it down on your keyboard as hard as you can a few times, this willl soften it up for the next process.
Using an eight inch angle grinder make your cuts diagonally from corner to corner taking care not to cut all the way through the casing, now take the unit and bend it over your knee, you should be able to crack it open using the described methods with little problem.
Please remember to use safety equipment/goggles at all times throughout the above process.
Posted Sun 18 Apr 10 @ 1:24 pm
Please support the software and its future development by purchasing it: https://virtualdj.com/buy/
If you can't afford Pro, then there are cheaper options available: https://virtualdj.com/products/comparison.html
Posted Sun 18 Apr 10 @ 7:44 pm
