Hello,
I am running Virtual DJ Pro version 6.0.5. (along with a denon HC 4500 controller)
I would like to create 2 keyboard shortcuts:
Load the currently selected track into the LEFT player when I press the "Left Arrow Key"
Load the currently selected track into the RIGHT player when I press the "Right Arrow Key"
I know that the keys I need to change are LEFT & RIGHT but I can not figure out what the action should be. Could someone please help by providing what I should have under "action" for this to work?
Thank you,
Robert Pfeifer
Pifemaster Productions
www.pifemaster.com
Thank you,
Robert Pfeifer
www.pifemaster.com
Posted Sat 06 Mar 10 @ 9:35 am
The easiest way is to look at the normal use.
One deck is usually playing when you load the idle deck.
If you create a one key shortcut and assign "deck default load" in the window, the selected track will load to the idle deck.
More info here;
http://www.virtualdj.com/wiki/VDJScript%20Examples.html
VDJ is as deep as you want to go, that rabbit goes a long way down that hole.
You can spend quite a bit of time figuring out the script commands and spacing/punctuation.
If you study that guide and do a little trial and error, you will see how complex it can be.
Before you get too deep into the keyboard, if you are not already, consider a control device also.
More info here;
Posted Sat 06 Mar 10 @ 10:52 am
You can use the HC-4500 scroll knob to find the track you want then press it in and it will load the track to the inactive deck.
Posted Sat 06 Mar 10 @ 10:58 am
