What are the professional sound cards recommend by the VDJ Team for use with 2x2 outputs and to mix on an external mixer ? I want to use only one pro sound card splitted into two outputs. I need the same audio quality in both outputs.
I was told that it is not possible to use two identical sound cards like for example two Sound Blaster Live 5.1. I was told that I should use two different brands. Is this true ? Should I go to a M-Audio Delta 44 for example ? Would VDJ Team recommend another option ? Thanks .DJ Elvert ( Brazil)
Posted Fri 15 Aug 03 @ 5:08 am
We definitely recomend using one soundcard with two outputs rather than two soundcards.
I think the Sound Blaster Live 4.0 is the best price for that quality. But any 4.0 capable soundcard will do.
Posted Fri 15 Aug 03 @ 4:59 pm
I`m using Sound Blaster Live 5.1 and it works great ! !
Posted Fri 15 Aug 03 @ 6:35 pm
Thank you Coco and the staff team for your reply.
I want to control VDJ desk 1 from my Pioneer mixer channel 1 and VDJ desk 2 from my Pioneer mixer channel 2.
Is this possible using only one Sound Blaster Live 5.1?
Posted Sat 16 Aug 03 @ 4:42 pm
Any SB live card will do. They're great ... sound much better than any ordinary generic sound card.
If you wanna go a little higher-end .... turtle beach ones are supposedly one of the best.
Posted Sat 16 Aug 03 @ 6:31 pm
HI Staff Internal Team,
Thanks for your help !
You recommended one sound card with two outputs. I tried my SB Live 5.1 this way, and everything is ok now.
Questions
In what situation should 2 sound cards be used ?
Do you think M-Audio Delta 44 is a better choise than SB Live 5.1 ?
Thanks again.
DJ Elvert
Questions
Thanks again.
DJ Elvert
Posted Sun 17 Aug 03 @ 5:32 am
What are the advantages of using one soundcard instead of two ?
Thank you
Dj Elvert
Thank you
Dj Elvert
Posted Mon 18 Aug 03 @ 4:32 am
Using one soundcard is always better.
Same sound quality, same volume, no need to adjust
gains to match the outputs, plus you dont have some
sync problems sometimes happen with 2 cards.
As for the M-Audio 44 if you have the money...
go with it.
The soundblaster lines are consumer quality soundcards,
while M-audio makes pro quality audiocards.
And i mean the quality of their DAC's
(because VDJ is so flexible and works with both)
I have a Hoontech DSP24 (they are like the M-audio)
along with a sblive and the difference in sound quality is obvious.
But i suggest you to take a look to the Audiotrak
cards especially if you want a usb solution.
They are very good for the money.
(I have Maya Ex 5.1)
go with it.
Posted Mon 18 Aug 03 @ 5:18 am
Hi Apopsis,
It was great to know that I can have sync problems,and I want to thank you very much for your tips.
Good luck !
DJ Elvert
Good luck !
DJ Elvert
Posted Mon 18 Aug 03 @ 5:50 am
