Hello my name is Pete in a Rock DJ from Wrexham UK, i'm currently running the DJ console MK2 (Virtual DJ 3.1) on my Macbook pro, i've had the console for around a month and no problems. But i was playing around with some settings and now my volume control faders, control the pitch instead, i've tried going into configuration and selecting " Enable, Invert Pict/Volume" but every time i select the Invert pitch/volume option and click ok, it just goes back to being un selected.
I have uninstalled virtual DJ 3 times and have checked for all driver updates but nothing seems to be working, it's probably something really simple but i'd appreciate it if anyone could help me out here!
Thanks
Pete
Thanks
Pete
Posted Thu 18 Feb 10 @ 9:54 pm
I have managed to fix the problem, i just uninstalled virtual dj and deleted all the VDJ files from the finder. (Big relief, as i have to DJ tonight :p )
Posted Fri 19 Feb 10 @ 9:44 am
If you are running v3.1, you should update to the newer Console Edition v3.4.
You can do this by registering the DJ Console Edition serial number (Found on the sleeve of the installation CD) to your profile on the page https://virtualdj.com/users/edit.html and then going to the Download Center: https://virtualdj.com/download/updates.html
You can also download the latest DJ Console drivers and firmware from the following page: https://virtualdj.com/wiki/Common_Device_Drivers.html
Posted Fri 19 Feb 10 @ 12:23 pm
