have a rmx and a korg kontrol.
i want to map one of the turning dials to the loop shift wheel.
But because the wheel on vdj screen is an endless(keeps turning) dial there is a problem. the only way i can map it is one dial to shift left and another to shift right, not good.
i only ever have to shift the loop a few 10ms either way.
any help will be apreceated
Posted Mon 08 Feb 10 @ 5:16 pm
If you are using Simple MIDI Wrapper, please see the bottom of https://virtualdj.com/wiki/VDJScript%20Examples.html for details on how to map endless encoders.
Posted Tue 09 Feb 10 @ 12:44 pm
so i would put
param_greater 50% ? loop_move +10ms : loop_move -10ms
this doesnt work sory my midi devise doesnt have an endless
Posted Tue 09 Feb 10 @ 2:47 pm
It's only possible to do that with an endless encoder, jogwheel or two separate buttons.
NOTE: Please don't quote/copy text from the message that you are directly replying to. It makes it difficult and confusing to read.
Posted Tue 09 Feb 10 @ 7:27 pm
