Forum: Old versions
Topic: Problems with Virtual dj!
Hi, i downloaded the trial to see if i could get to grips with virtual dj, i am having a toss up between this and bpm.
the user interface is a lot easier on this than bpm, my problems are these.
ive used it for 2 gigs now, on both occasions its just closed down, no warnings, no screens just stopped dead.
i've also had a few occasions where it stops but gives you the warning its going to stop.
im running windows 7 ultimate on a brand new sony vaio.
i also use it for doing karaoke.
i love the program, just cant trust it to do the job, i'd love to iron out the problems im having and buy it, but until i know i can run it without issue, i'm tempted to go with bpm.
Any help would be great......
Posted Mon 01 Feb 10 @ 7:08 am
is your windows 7 the 32 bit version or 64 bit?
What video card is on the Sony?
What kind of files are you playing?
Quote :
in this case a crash report was made. go to the PC Tech support forum
https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
the first 'sticky' there explains how you can post your "crash report".
