one in asio mode for my tcv and other one for samples ???
Posted Fri 13 May 05 @ 5:08 pm
maya can handle it all...
output 1&2 for deck1, 3&4 for deck 2, and 5&6 for samples
Look in TC output settings
You can also set up this in advanced settings for using a different soundcard for samples.
I think that will work, if you choose only the sampler settings
Not sure
Not sure
Posted Fri 13 May 05 @ 5:34 pm
I use djconsole + ozone (in asio for samples)?so its already possible
2 sound cards....My dj console is not in asio mode...still works
Andre
Andre
Posted Fri 13 May 05 @ 5:47 pm
I'm talking about maya 44 usb (2 outputs) with asio drivers and TCV -
and the posibility to use another sound card (non asio) for the samples .
Posted Fri 13 May 05 @ 6:19 pm
ok... thought maya had 6
well, try this :
1. set up maya normaly for timecode use (low latency setting)
2. Go to advanced setting, and set other card for sampler
might work, not sure
well, try this :
Posted Fri 13 May 05 @ 7:21 pm
I had started with the Gigaport AG and then got the Maya for the inputs for TCVs.
Now you would think since ESI/AudioTrak are the same company, they would make their devices compatible. Well that wasn't the case, at least in my initial attempts. I didn't have that much time to really mess-around with trying to make them work.
As for dj-in-norway's comments - I thought you could only have 1 Sound card configuration selected at a time in VDJ. Can you really go to ASIO Low Latency and configure it, then go to Advance and configure a second device and still retain your ASIO configuration?? I would think the last sounce configuration setting you selected would be the setting of choice??
Help if I am wrong? Because this could explain some issues that I have seen in the forums.
cstoll
Posted Fri 13 May 05 @ 7:55 pm
you might be correct cstoll.... I have not tested... was just an idea for Man TK to test, if it worked. Probably not
Posted Fri 13 May 05 @ 8:05 pm
