Numark - V7
The turntable, evolved.
V7 is the turntable for today’s DJ. V7 delivers outstanding feel and unprecedented power in a single-platter digital DJ controller. V7 is based around the acclaimed adjustable torque, motorized-platter design from Numark's NS7 and delivers a host of professional features including real vinyl and a slipmat that analog turntablists will love, plus turntable control at ten times the resolution of standard MIDI, mouse-less library navigation, and Strip Search virtual-needle drop. V7’s link function enables you to combine multiple V7s with your choice of any mixer and your Mac or PC for a completely customizable, totally seamless performance environment.
V7 includes a professional 24-bit audio interface and contains premium faders, knobs, and buttons including controls for selecting tracks and blending audio effects in the included Serato ITCH software.
PERFECT FEEL
Forget your experiences with other controllers. V7 has a seven-inch, motorized, high-torque aluminum turntable platter. The turntable features modern and classic settings that alter the feel to model the feel you prefer. A seven-inch, legit vinyl record with 45RPM adapter sits on a real slipmat. There’s no simulation here – V7 is the real deal.
We used nothing premium, rugged, rubberized buttons and knobs for an unquestionably high-quality feel. Its recognizable, professional appearance is supported by clean design in matte and glossy black. V7 is housed in a heavy-gauge, industrial-strength metal casing that is ready for the torture of travel.
PROFESSIONAL SETUP
Forget the mouse. Forget the keyboard. V7 renders software perfectly simple to operate, with its click knob and large, backlit buttons navigating though your music library. You’ll spend less time looking at the screen and more time enjoying performing thanks to the visual feedback you get from V7’s extensive LEDs and hands-on controls.
Grab a pair of V7s and your favorite mixer, such as DXM PRO, and you’re ready to rock. V7 has onboard audio outputs so it’s the only piece of gear you need to connect to the PA system or powered speakers. The front panel contains mic input, RCA line input, and both 1/4" and 1/8” headphone outputs with volume control.
To complete your system, you can add our LAPTOP STAND to elevate your computer to comfortable height. Our custom 7-INCH COLOR VINYL records enable you to customize the look of V7 with eye-catching, translucent looks.
PRECISION CONTROL
V7 sends control information over USB at more than ten times the standard MIDI rate. This innovative communication technique yields extremely high-precision, low-latency control.
There’s nothing like dropping the needle on a record for quickly locating a point in the track. We took that idea and developed our own modern take on it with Strip Search, the unique virtual-needle-drop touch strip. You can locate a point instantly within the track using the on-screen waveform and Strip Search.
Five hot-cue-assign buttons on each deck digitally mark your cues on the track. These marker points are recallable in ITCH, and you can even load Scratch LIVE cue points in ITCH.
We developed an extensive loop-controls section for creative remix capabilities. You can choose between manual and auto-loop functions and an automatic BPM analyzer further assists loop makers. Creating automatic smart loops of any measure length is a breeze, and you can mutilate and modify to your heart’s content with a variety of controls such as Doubling, Halving, Shift, and manual controls. Multiple loop banks make V7 a great choice for scratch and club DJs alike.
Beat matching is straight ahead with 100mm, smooth, stiff pitch sliders and plus and minus buttons, by popular request, for bending. There’s a zero-point LED, so it’s easy to know when you’re in the middle.
AUDIO QUALITY
We took extraordinary care in selecting the components of the audio signal chain. V7 contains a host of professional audio connectors and a multichannel, 24-bit USB digital-audio interface. It outputs high-resolution, 24-bit audio to the sound system on XLRs and RCAs.
The high-definition post-mix analog audio output features a minimized circuit path with containing only one audiophile-grade bipolar capacitor. This optimized design maximizes phase coherence, ensuring that audio is tight and punchy.
http://www.numark.com/v7
PERFECT FEEL
PROFESSIONAL SETUP
PRECISION CONTROL
AUDIO QUALITY
Posted Wed 13 Jan 10 @ 5:03 pm
a prima vistà ho pensato, oddio a bazzooka si è spezzato l'NS7 :-)
poi mi son ricordato che l'ns7 non ha un vero mixer e magari a chi piacciono sti cosi motorizzati questa poteva essere uan bella soluzione,
non c'è che dire a questo giro la numark le ha pensate proprio tutte !!!!
Posted Wed 13 Jan 10 @ 7:31 pm
Io invece mi sono detto:chissà quante belle cosine ci farà bazzooka con questo controller :)))
Però niente male e quanti bei tastini da mappare.
Posted Thu 14 Jan 10 @ 12:12 am
Salve ragazzi ho bisogno del vostro aiuto,da poco ho acquistato n.2 numark v7 dopo aver installato tutto quando vado a far partire vdj lui mi vede il v7 come scheda audio e riesco a configurare tutto in modo corretto,ma non riesco a far comunicare la parte midi,il vdj non mi vede la V7 come controller,come posso risolvere tale problema.Grazie
Posted Sun 25 Apr 10 @ 11:39 pm
Ringrazio i ragazzi per le risposte nell'altro post,allora ieri sera ho visto che tra i controller disponibile compare la voce V7,come la voce NS7 quindi dovrebbe essere gia mappata,ma quando chiedo a vdj di vedere i controller collegati su la voce mapper del software lui non trova niente,per Bazzooka come si copiano le actions che dicevi tu grazie.
Posted Sun 25 Apr 10 @ 11:45 pm
Stai usando l'ultima versione 6.0.8 vero?
http://it.virtualdj.com/download/updates.html
Proprio nella 6.0.8 è stato risolto un bug sul V7 e la mappatura è nativa, nell'altro topic ti erano state date informazioni in parte errate.
fixed multi-deck issues with V7 and HS5500
http://it.virtualdj.com/wiki/VirtualDJv6.0.8.html
Se non funziona anche nella 6.0.8 contatta pure l'assistenza http://it.virtualdj.com/contact/index.html
Posted Mon 26 Apr 10 @ 1:22 am
Grazie Cioce oggi provero' a fare delle altre prove vediamo cosa succede il mio sistema operativo e Mac mi ero dimenticato di dirlo prima.
Posted Mon 26 Apr 10 @ 5:09 am
Niente ragazzi ho provato in tutti i modi ma non vuole sapere di funzionare in midi,la scheda audio la vede benissimo e funziona tutto ma la parte midi non riconosce niente e tutto fermo,sono andato nelle impostazioni del mio mac e rileva tutto correttamente sia la scheda audio che la parte midi,ma vdj non trova niente al momento del collegamento,ho provato anche con windows ed è la stessa cosa vede bene la scheda audio ma non funziona niente in midi.
Posted Mon 26 Apr 10 @ 9:56 am
Non ti rimane che...
Disponibili i driver stabili v2.9.13 per Windows Vista e Seven 64 Bit
http://www.numark.com/content255772.html
Posted Fri 07 May 10 @ 2:03 am
Mi è capitata la possibilità di acquistare due Numark V7 ex demo (a metà prezzo) ora, visto che alcuni di voi sanno che sono un vinilista vecchio stampo... :-) e che i V7 sono quello di più simile ad un "SL1200 controller midi" vorrei sapere se (e qui chiedo ai guru del settore), avendone una coppia e avendo la possibilità il V7 di switchare il deck, sia possibile utilizzarli con VirtualDj in modalità 4 deck.
Già so' che sarà una configurazione che utilizzerò il 10% delle volte, ma avendone la possibilità e visto che questo benedetto 4 decks sta "andando di moda" ;-) , è sempre buono avere qualcosa tra le mani da poter utilizzare in un successivo eventuale futuro.
Anche se a me farebbe comodo utilizzare l'ulteriore deck a disposizione (di solito lavoro in modalità 3 decks) inserendo una traccia di riserva sempre pronta all'evenienza del momento (i cambi di programa nel mio settore sono sempre in agguato! :-) ).
Thanks! ;-)
Edit by Cioce
Eliminata firma, le firme pubblicitarie non sono ammesse in questo forum
Thanks! ;-)
Edit by Cioce
Posted Sat 22 Jan 11 @ 5:45 am
le V7 si possono comportare esattamente come qualsiasi altro deck
sono mappabili in tutto e per tutto
ed e' quindi possibilissimo indirizzarle a controllare qualsiasi deck numerato
o riferito ai lati del crossfader.
Il vantaggio delle V7 e che le puoi collegare tra di loro via LAN (anche piu' di 2)
e occupare una sola USB del computer,
ma la NON E' MIDI, e quindi funziona solo con i software programmati apposta per riconoscerla e gestirla,
ma VDJ, grazie a un accordo con Numark, e' uno dei pochi che funziona.
Augh !
Augh !
Posted Sat 22 Jan 11 @ 7:25 am
