hi guys.. i need your oppinion and help about my problem...
i am running on 2 turntables, time coded vinyls and a maya 44 usb card. but everytime i drop the needle on the vinyl, vdj is spinning backwards.
please help.. thank you
Posted Mon 11 Jan 10 @ 11:42 am
under config window invert signal phase and or invert signal stereo.
Posted Mon 11 Jan 10 @ 2:25 pm
i hope this works... thank you very much
Posted Mon 11 Jan 10 @ 5:22 pm
thanks dude... i have config my set up and everything works out fine... except for the digital sound that came out after letting the program sit w/o playing for 30 minutes. with the rest.. everything was cool.
thanks again.
thanks again.
Posted Tue 12 Jan 10 @ 8:24 am
Could be a result of using an illegal copy of the software, trial version has it's limitation also in timecode.
Please purchase it in here https://virtualdj.com/buy/ otherwise you can buy Numark Cue or Virtual Vinyl on Numark's designated outlet in our country.
Cheers
Cheers
Posted Wed 13 Jan 10 @ 1:00 am
