Hi everyone,
Please i want to know what do you think of the external sound card Trust 5.1 and if it can work for monitoring my headphones 3.5mm mini jack on VDJ
Thanks a lot
Thanks a lot
Posted Sat 02 Jan 10 @ 2:55 am
It will work, but i dont know nothing about quality of this product.
Regards Tjeck
Regards Tjeck
Posted Sat 02 Jan 10 @ 4:35 am
Hi mate
V basic card. If you can stretch the budget a little have a look at the offerings from Creative labs.
Also be aware that depending the version of VDJ LE you are using there may be limitations on what external cards you can use.
Daz
Daz
Posted Sat 02 Jan 10 @ 4:58 am
@Dazmax :Which Creative's product do you advice me ?
What do you think about Soundblaster Audigy ?
Posted Sat 02 Jan 10 @ 5:07 am
I started out with the trust 5.1 external sound card for monitoring. Served me very well used it for around a year before upgrading to a numark dj io.
Posted Sat 02 Jan 10 @ 5:41 am
Thanks a lot Rob, you saved my life lol
I will buy it today ^^
Posted Sat 02 Jan 10 @ 5:42 am
if you want help in setting up with your 5.1 then do a search of my username and there is a how to that i wrote some time back.. this will help .
Posted Mon 04 Jan 10 @ 2:59 pm
Hello! I have a problem with monitoring for my Hercules Steel + Muse Pocket LT.
The headphones do not work at all. I used to have this problem before but then I found the appropriate settings. Unfortunatelly I don\'t remember it, so after changing the active sound card (Muse LT) for Realtek, and then getting back to the Muse Pocket LT, I can\'t make the monitoring work - there\'s only one, Front Audio channel which works....=(
Could someone help me please?
Posted Sat 23 Jan 10 @ 6:22 am
