Forum: Old versions
Topic: Problem with Siund noise using Hercules
I work with HP notebook and Hercules . I have a major problem with noise which seems that comes from HP power suplier because when i disconect it from HP the noise disappears .Any tip for that ?
Posted Tue 10 May 05 @ 12:07 pm
its called ground loop... very common with computers
To get rid of it, try connecting the powercord to a powersupply without ground
Or get a ground loop eliminator from your local radio store
thanks for your interesting but i didn't get it . You mean change the supplier ?
if your power cord looks like 3 circles in a triangle (the part that plugs into notebooks powersupply)
you can use 2circle (wire) whitch is normally used for radio or shaving-machines
you just have to cut it with the knife in the middle in order to enable it to stretch a little and fit
into the bottom 2 holes in your power supply. This solved my ground loop problems
your new power cord should look like this
http://www.bearpwr.com/images/2%20conductor.gif
your old was like this one:
http://www.bearpwr.com/images/3%20conductor.gif
the side which you plug into wall is probably different than show on the pictures ..
no this is the USA powecord , here in greece is with 3 fat circle jacks at the end
Ground loop eliminators are cheap. $15 here in the U.S. You could probably get a 3 prong ->2prong adapter for $2.
I'd recommend either of those solutions over performing surgery on your power cord.
Here is a ground loop isolator $16.99: http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-054 This exact unit solved my groundloop noise problems.
And here is a 3 prong ->2prong adapter for the power cord that might do the trick, too. $2.99 for two. This might not fit your particular style of plug, but should give you and idea of what to look for as well as a clue to the price. http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=61-2720
or you could just get a power extention cable, that does NOT have ground, and connect pc to that...
Get a 2 prong adapter witch converts a 3 prong to a 2 prong. It will ground it for you. they cost about 3 or for dollars
