I have nos sound from my sound card with tcv.
I have a audigy2 asio drivers work
turntable grounded to computer
sound card connected to mixer
Nothing but humming noise and no music at all.......where did I go wrong.
Posted Sun 08 May 05 @ 6:37 am
you need some ground loop eliminator or you need to ground your turntables to your pc case...
Posted Sun 08 May 05 @ 7:22 am
My turntable is grounded to the pc and the other end is connected to the turntable.
Posted Sun 08 May 05 @ 4:51 pm
Seems like a config issue or a hookup problem if you're not getting any sound/music. Did you follow the instructions closely for hooking up TCV? Perhaps you didn't select the right config in VDJ for TimeCode. I would make certain you review that. Grounding is important for the best sound but it usually works even if it's not grounded I've found. Are you getting good signal strength from the TCV?
Posted Mon 09 May 05 @ 3:49 pm
