Forum: Old versions
Topic: mic for vdj and bcd3000
HI ALL I HAVE JUST GOT A BCD300 WITH VDJ 5.0.7 ALLL WORKS OK APART FROM THE MIC I SEE THE CLIP LIGHT WORKING AND HAVE SET THE MIC A INSTRUCTED IN THE BOOK BUT IT STILL WONT WORK
HHHHHHHHHEEEEEEEEEEELLLLLLLLLPPPPPPPP PLAESE
Posted Tue 01 Dec 09 @ 4:03 pm
Version 5.0 rev. 7 is about 2 years old !!! Please register your version and update to the latest 6.0.4. There are tons of bugfixes since your version.
Greets, Heiko
NOTE: If you are using an illegal version of the software then that will be why you are experiencing problems. If this is the case, please support the software and its development by purchasing it: https://virtualdj.com/buy/ - Also, check your computer for viruses and spyware which often accompany illegal software.
HAHAHAHAHAHAHA!!!
Did you hook your mic up to your BCD3000 or your laptop?
