Harmonic mixing is the natural evolution of beat mixing: mixing in compatible keys. You can now avoid sour mixes caused by clashing melodies. You can mix long overlays without depending on percussion "free beats." You can achieve those "screamer mixes" which provide the ultimate DJ rush!
Camelot Sound provides both types of information needed to program harmonically: keys to each song and key compatibility. Our database (updated monthly) contains bpm/key information on over 32,000 songs. Our Easymix System makes harmonic programming as easy as telling time and gives the DJ the proper tools to fully express his artistry.
Until now DJs with an ear for music avoided sour mixes by using percussion breaks or "free beats" from one of the songs being mixed. His artistry was severely limited in the same manner that a painter's would be, if the painter could never mix colors together, or if he could only mix every color with grey. Harmonic mixing is the technique of mixing different keys artistically, instead of randomly, in order to create musical blends rather than bland or sour mixes. i just hope we get keycode display in the nex up date.
Posted Sat 30 Apr 05 @ 4:24 pm
10-4 on that.
Posted Sat 30 Apr 05 @ 7:21 pm
Amen....DJ Phil it
Best regards and better mixes to you
Andre
Andre
Posted Sun 01 May 05 @ 5:17 pm
