Hi all,
I've just bought a creative pcmcia sound card with asio 2 drivers and having a bit of trouble setting it up to work with vdj. Funnily enough I had it working fine at one point but I have no idea what has happened since.
There is 3 cables outputs from the sound card. 1 for the left channel front & rear. 1 for the right channel fron & rear. 1 for the use with a subwoofer. There is a dialogue box in which I can choose the config for the soundcard choosing options either 2.1, 4.1 or 7.1.
I'm running 2 xp10's off two speakers with an external mixer and amp. Any ideas which settings I should choose in the creative config menu and also what settings should I use to correspond in vdj?
Any help would be appreciated.
Posted Thu 28 Apr 05 @ 1:46 am
ignore post... i figured it out... duh!
Posted Thu 28 Apr 05 @ 10:24 am
