hi guys. i mainly use Traktor pro. in traktor when i turn on the PFL for a deck it lets me listen to the deck without it going through main speakers if my fader is at 0. in vdj all its doing right now is changing witch deck shows up in front in the waveform window.(2 deck) I want it to work like in traktor. help pls. thx.
Posted Tue 08 May 12 @ 10:14 am
In VirtualDJ it does the same, just like any conventional standard hardware DJ mixer would.
If it's not working then it means that your sound is not setup correctly.
Please see:
http://www.virtualdj.com/wiki/Pre-listen%20using%20headphones%20in%20VirtualDJ%20Home%20FREE%20or%20Broadcaster.html
http://www.virtualdj.com/wiki/PDFManuals.html
http://www.virtualdj.com/wiki/FAQ.html
http://www.virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
NOTE: If you can provide more detailed information about what sound card(s), hardware, etc. that you are using then it should be possible to give you a more specific answer.
Please see:
Posted Tue 08 May 12 @ 6:01 pm
Question how can i stop pfl from changing to the other side when i load a new song?
Posted Tue 13 Aug 13 @ 9:42 pm
Settings -> Options -> Auto headphones -> disabled
Posted Tue 13 Aug 13 @ 9:56 pm
Thanks for the help
Posted Tue 13 Aug 13 @ 10:09 pm
Sorry to dig his thread up but I really need some help here.
Im going to give you my equipment list:
I have a Yamaha PA sound system that includes a EMX660 powered 6 channel mixer, two Se15 15" 2-way cab speakers, the cables for the speakers, a mic with the XLR, and an RCA cable to plug into my laptop.
I would like to be able to listen to a song cued up on, say... deck 3 while deck 2 is playing. *Side note* I have a pair of Beats Mixr's.
In order to do that, I believe I need a sound card because even though I am able to plug my Beats Mixr into the mixer (with the phone jack thing) there is no PFL software/design built into the mixer.
So, lets say I get a sound card and plug Beats Mixr's into it and the EMX660 (which goes to the speakers). How do I activate a PFL channel on Virtual DJ so like I said before... while Deck 2 is playing, I can listen to deck 3 in my headphones?
Sorry if this is long and confusing, I just am not really that sure about how to do this.
Thanks for any help!
Posted Fri 30 May 14 @ 10:18 am
What you've got there is a PA mixer/amp designed for use by musicians (who don't need to cue).
Looking at it, I don't think it's even stereo.
You'd be better off starting over with the correct kit IMO. Get yourself a DJ mixer or a controller with onboard audio.
Posted Fri 30 May 14 @ 10:38 am
