Hi again.
Firstly thanks so much for your help with my questions - really helpful.
I have emailed support regarding this next question but wanted to run it by incase any of you had experience.
Bought VDJ - installed it but now thinking I would have preferred to have installed it on my more powerful laptop. Is there any provision to transfer my license to a different computer?
Thanks!
Thanks!
Posted Tue 26 Apr 05 @ 1:15 am
I think you can install it on a other machine, but you can use only one at a time and you can't give your code somebody else.
Posted Tue 26 Apr 05 @ 1:25 am
exactly :)
you can install the software on more than one pc
but it can only be used by you, and only at one pc (or more if in same room) at a time
Posted Tue 26 Apr 05 @ 1:36 am
Indeed support have been helpful and I am able to transfer it - 3ghz machine here I come!
Thanks guys.
Thanks guys.
Posted Tue 26 Apr 05 @ 2:32 am
