Forum: Old versions
Topic: Does the Pioneer MEP7000 work with VDJ
I'm interested in purchasing the Pioneer MEP7000, however, it is not clear to me if it works properly with VDJ. Furthermore, how would I connect the MEP7000 to my laptop. Woud I need an external sound card or do the dual drives act as a sound card?
Also for current Pioneer MEP7000 users, what's your feedback? Is it a good unit? I'm currently using the denon HC4500 which works very well with VDJ but want to switch.
Posted Wed 30 Sep 09 @ 12:19 pm
Search is your friend .......
The Asio sound card is built in to the base unit. If you use just the SEP-C1 on it's own you need an external card.
It does seem to work well with VDJ, but I use the HC-4500 which is as good as it gets so you'd be paying all that extra money for a drive unit and some eye candy. I decided against it although it is a beautiful and well built piece of kit.
https://virtualdj.com/forums/116290/PC_Version_Technical_Support/Audio_Pops_v6_0_2_with_Pioneer_MEP7000.html?search=mep7000&page=1
https://virtualdj.com/forums/114385/Hardware_Technical_Support/Pioneer_MEP-7000_and_VDJ.html?search=MEP-7000&page=1
https://virtualdj.com/forums/116065/Hardware_Technical_Support/Any_Success_Stories_with_Pioneer_MEP-7000_or_SEP_.html?search=MEP-7000&page=1
