i have tried to download the skins from this site but keep getin error msgs wots goin on please help coz this is sending me maaaad
Posted Sat 23 Apr 05 @ 7:24 pm
you have to look for a skin that's compatible with your version...
mixstation 2
mixstation 2
Posted Sat 23 Apr 05 @ 9:31 pm
how will i know do i just have to try them all till i find 1 that works?
Posted Sat 23 Apr 05 @ 11:32 pm
yes that's it. Sorry for that. Skins are made for Virtual DJ in a first time but some are compatible with DJ Mix Station 3. Do have more luck with DJ Mix Station 2 look at the first release (old )
If you can tell us at the same time which skins work ;-)
You can create a special post only for that
Posted Sat 23 Apr 05 @ 11:44 pm
