I had experience of this around version 2 and noticed that speeding up the tempo even by a little resulted in some kind of loss of accuracy within the beat of a track, often resulting in a lilt in the rhythm...is this still an issue for anyone? Or is this something that was noticed and has been fixed?
best
PaulyV
best
PaulyV
Posted Tue 19 Apr 05 @ 11:32 pm
if you use versions later than 1.09, you use cracked versions...
than you ask for broblems...
Posted Wed 20 Apr 05 @ 11:57 am
? Is the version I have bought not version 2.something? I assumed ti would be.
Posted Mon 25 Apr 05 @ 12:49 pm
As a professional user you should have the 2.06 version.
Check the number on the splash screen (when VDJ starts).
Posted Mon 25 Apr 05 @ 2:32 pm
