Forum: Old versions
Topic: Major timecode problem - Page: 1
So, yesterday I plugged my computer into my friend's SL-1 box to do a gig. I loaded up VDJ 5.21 and it was having trouble using the SL-1 box w/ the Serato timecodes. I was frustrated because I've been using those two w/ VDJ 5.21 for months now. The left deck's audio kept getting wobbly (best way to describe it) and the timecode signal kept dropping to 0%. (I am using CD timecodes)
Today I hooked up my SL-1 w/ VDJ timecode and had the same problem. The weird thing is that w/ the Serato timecodes, Serato itself has no problems with the SL-1 or the signal dropping, so it has something to do with VDJ. Is there a way to get a copy of the 5.21 install? I'd like to uninstall the software and re-install it altogther. I've tried system restores to before the gig and they haven't worked.
To recap - VDJ and SL-1 timecodes give same problem with "wobbly" sound. It especially will happen if I adjust the pitch (and I know that I shouldn't have key-lock on, it's not) or scratch. It will work fine for a while, then crap out when I try to scratch or change the pitch. ARGH. It's very frustrating and I have a very big important gig on Saturday that I have to have this working by. PLEASE help. This happens in both 5.2.1 and 6.0.1.
Posted Mon 20 Jul 09 @ 1:57 pm
Please post screenshots of the timecode signal
I am trying a system restore - once it comes back up I'll post screenshots.
It is just so friggin random. I don't get it. It has worked using a SL-1 box for a few months without a single problem. I plugged my computer into my friend's SL-1 and it goes CRAZY. Just nuts. I can't even get a system restore to work right now.
Cel, is there a way to talk via AIM or Gchat? This gig I have on Saturday is monumentally important to me (I'm flying cross-country for it) and I am desperate for help.
The weird part is that it's almost always (99.9% of the time) on the left deck. Right deck is rock solid. Doesn't matter what decks, cables, etc that I use. And Serato will work fine with the same setup. So it HAS to be something internal to VDJ. I am literally an hour away from just reformatting.
djpoopypants wrote :
http://i26.tinypic.com/6530ax.jpg
The gain in the audio inputs are clearly too high according to this picture. Go to your sound card and decrease it
Yes I know. But that's not the issue. The gain is fine in the first picture.
You can basically ignore the second one.... that was just a bunch of crap going wrong at once. Mostly its just the left deck getting "wobbly".
The thing is that it will be fine for a while, then it will go all wonky, then be fine again. It just doesn't make any sense.
Ok so it's time to reset the sound drivers. Go to Infos pannel and click on "reset to factory".
You will have to set all your params then but you will be sure vdj has loaded the right audio drivers.
Now both are messed up. Both are fluctuating between 0% and 100% constantly. And they're still going to 100% and then breaking down, then going back.
ok so it's time for the solution B
0) make back-up of folders and database
1) Uninstall VirtualDJ
2) Download registry tool
https://virtualdj.com/addons/2170/Registry_Tool.html
3) Launch it and click on the button "clean"
4) Accept the remove of the data (you won't loose your database)
5) Disconnect your sound card
6) Reboot your computer
7) Connect your sound card when Windows is at the desktop and be sure it works ok
8) Maybe resinstall your sound card at this step with a reboot of your computer
9) Install VirtualDj (you will need your serial number)
No change. Same problems.
Hmmm. Interesting. I'm trying my Maya 44 USB card to see if there's a difference.
The Maya 44 seemed fine. So I'm guessing it has to do with something about the SL1, VDJ and how they're interacting. I'm going to uninstall all the drivers for it, reboot, and try again.
Still nothing. Uninstalled, reinstalled, did all the drivers. Nothing. SL-1 still doesn't work right. Maya 44 seems okay but I'm going to have to test the crap out of it.
Anything you can think of? Why it would go to 100% for a minute, then down to 10%-90%, then go back to 100%?
I thought the power might be an issue, but I plugged the SL1 in and it still has a problem.
Reformatting now. If this doesn't fix it, I'll cry.
:cries:
I have no idea what could be causing this. Not even the reformat fixed this. Fuck.
Any ideas? I'm stumped. The timecodes still read fine in Serato, but not in VDJ.
71%
