Hi, I need help with how to mapp vci 100 with virtual dj im new to this and am lost any help thanks so much for your time.
Posted Mon 13 Jul 09 @ 11:12 pm
The VCI-100 is already mapped in V6
Posted Tue 14 Jul 09 @ 8:54 am
The VCI-100 is native supported - also you can download one of my advanced mappers for the VCI-100:
for the normal VCI-100 you can use: https://virtualdj.com/addons/8402/Vestax_VCI-100_Mapper.html
and for the VCI-100 SE Edition from DJ Tech Tools you can use this one: https://virtualdj.com/addons/8401/Vestax_VCI-100_SE.html
Greetings, Heiko
Greetings, Heiko
Posted Tue 14 Jul 09 @ 2:11 pm
Just got my VCI-100, the mixer came with both Traktor and Mixvibes? Is the firmware on the VCI-100 different then since it came with Mixvibes too? Reason I ask, I used to have a VCI-100 and it just came with Traktor. It also let me play the sampler sounds using the four bottoms toward the top right. Now when I use the new VCI-100 that came with mixvibes those 4 buttons control effects not sampler. Is my new VCI-100 different? I've tried the new mapper from download section as well as the native mapper that came with VDJ6 and I am also unable to scratch. My old VCI-100 would scratch a lot better than this new one. Kinda disappointed. Any ideas. Thanks.
Posted Wed 12 Aug 09 @ 10:59 am
All the buttons on your controller are just MIDI knobs. The action which is called is directely controlled by the software you use. So every software use it's own mapping of the controller.
Greets, Heiko
Posted Thu 13 Aug 09 @ 7:52 am
makes sense. thanks for your response.
Posted Thu 13 Aug 09 @ 8:16 am
i need help to map it so i can pitch bend i play house and electro
thanks
Posted Thu 08 Oct 09 @ 11:00 pm
Hey djmikemagic,
use the outer wheels to pitch bend a track.
It is already mapped.
Haui
Posted Fri 09 Oct 09 @ 4:52 am
