Hi All
I know that this is not a DJ or VDJ FAQ but I need help, I keep getting a error like this
Application error
The Instruction at "0x........."(any number) referenced memory at
"0x0..." (any number). I get this when I open or close some programs.
Can anyone help me?
My CPU
p4 2.8 (motherboard asrock p4v88)
ram 2gib (pny 2700)
video card (ati 9800 pro)
Thanks
Application error
Can anyone help me?
My CPU
ram 2gib (pny 2700)
Thanks
Posted Sun 03 Apr 05 @ 2:48 am
Sorry Man...got nothing for you.
Posted Sun 03 Apr 05 @ 4:54 am
hee audio...
do you have two memorycards of 1 gb ram in your pc?
i don't know if that's the problem, but i know it will sometimes give problems....
Posted Sun 03 Apr 05 @ 7:47 am
I have 4 of 512ram. Why does windows say I only have 2gig I should have something like 2.48 gig?
Posted Sun 03 Apr 05 @ 10:55 am
Not 2.48 but 2.048 Maybe it doesn't displays at 0.0xx
Posted Sun 03 Apr 05 @ 12:08 pm
One thing I would try is removing 1 stick of memory and try to reproduce the error. If the error occurs again try swaping another stick of memory until the problem goes away or all memory sticks have been tested.
This problem often occurs with a bad stick of Ram, it has happened to me in the past although if its not memory its more then likely a Windows issue.
Let us know the results
DJ White Devil
DJ White Devil
Posted Sun 03 Apr 05 @ 4:24 pm
DJ White Devil
I have tryed just what you said but I get the same thing. Could it be something in my bioss
I see some setting there for memory. Windows XP is a new install.
Posted Sun 03 Apr 05 @ 4:33 pm
did you check to see if Window's virtual memory is set to auto? I only once had problems related to me manually setting the virtual memory.
Posted Sun 03 Apr 05 @ 4:34 pm
Windows virtual memory is set to "let windows choose whats best for my pc"
Posted Sun 03 Apr 05 @ 4:54 pm
well that's ok, This is what I had to chose to solve my problem although at this point I'm out of ideas.
If I think of something else to try I'll post here. When are you getting this error exactly? when opening VDJ? or after trying to use an effect....
DJ White Devil
DJ White Devil
Posted Sun 03 Apr 05 @ 4:58 pm
I get this error when I try open or close any program
Posted Mon 04 Apr 05 @ 12:51 am
Is anyone els useing a asrock motherboard p4v88 and if so what memroy do you us? Or any motherboard by asrock. I need a new motherboard what should I get? I would like not to buy new parts, this is what I am working with.
p4 2.8
4 2700 memroy (512)
AGP video card
p4 2.8
4 2700 memroy (512)
AGP video card
Posted Tue 05 Apr 05 @ 1:16 am
