I think that the buttons and the sliders are MIDI, and the jog is HID.
But I'm not sure that is posible.
With your HID definition file, the jog is the only one to work, and with the general midi, the jog is the only one not to work.
Posted Fri 19 Jun 09 @ 2:36 pm
Anyone have solved the problem with 2XP5 and VDJ 6? I´m still using VDJ 5.2.1 and it works great..is it posible to make my XP5 work with VDJ 6?
Posted Wed 12 Aug 09 @ 8:30 am
kolynn sampler wrote :
Well, I spoke a little bit too fast.
Now, everything work well with my xp5, and I can scratch, and use the jog as before.
That's what I've done:
1) With the general midi mapping, I mapped my xp5 as I would like to
2)I downloaded cstoll's mapper engine.
3)On "EKS xp5 definition", I wrote this:
<?xml version="1.0" encoding="UTF-8"?>
<device name="XP5" author="Atomix Productions" type="HID" vid="0x1157" pid="0x0202" reportsize="32" decks="1">
<page type="in">
<jog word="0" endian="little" full="20960000" name="JOG" />
</page>
</device>
That's all!
Thanks to cstoll to help us!!!
Kolynn Sampler
<page type="in">
</page>
</device>
That's all!
Kolynn Sampler
Posted Fri 14 Aug 09 @ 12:43 am
Hi Kolynn, I tried your instruction & all seems to be working but the jog/scratch wheel? scratching is erratic. When a track is loaded & unplayed or stopped, VDJ makes a jocking sound as if the scratch wheel is being touch when actually, it's not. And when the track is playing, moving the jog or scratch wheel moves the track forward or backward with too much a speed, as if fast forwarding or rewinding. If yours works ok with yours, Pls can u help with a solution, plzzzzz.
Posted Sat 15 Aug 09 @ 1:02 am
Please try these new files if you have the XP5 - https://virtualdj.com/addons/8317/EKS_XP5_Def___Mapper.html
Posted Thu 20 Aug 09 @ 1:52 pm
Hi,
I didn't manage to configure my 2 XP5.
When I click on the link i have an error message :
Sorry, you don't have the necessary accreditations to view this page.
Can you help me?
thanks
Can you help me?
thanks
Posted Thu 08 Apr 10 @ 7:19 am
The Definition and Mapper are now available again ... https://virtualdj.com/addons/8317/EKS_XP5_Def___Mapper.html
Posted Thu 08 Apr 10 @ 10:17 pm
