ok the endless selector , bck and fwd button fixed
prepre = playlist
thanks
prepre = playlist
thanks
Posted Wed 08 Jul 09 @ 8:20 am
pitchbend progressif fixed
@tjeck1972
can you get me a cc code for the vinyl touch . we have only cc codes for the plater rotation ?
and then we can create a
JOG_TOUCH action="scratch_wheel_touch" />
thanks
@tjeck1972
thanks
Posted Wed 08 Jul 09 @ 9:14 am
@Djmola
Will try later this evening. Now i will rest.
Tjeck
Tjeck
Posted Wed 08 Jul 09 @ 9:23 am
ok tjeck
i just have the browse touchpad fixed ! it works correctly .
see you this eveniing
Posted Wed 08 Jul 09 @ 9:40 am
As i see, we have to make variable to cc="0x00" and cc="0x02"
Tryed fix faderstart and xfader reverse to work corectly and fix the leds under vumeters, but they have strange adresses:-?
They are allready in use like jogs.
Posted Wed 08 Jul 09 @ 9:54 am
Hello Voila j the moving plate but j has to defuse(unsettle) my ns7 to have code of the vivyle sound arrives not has to use noon(south) - ox
Posted Wed 08 Jul 09 @ 11:08 am
djmola voila toi tu pourai mieu me conprendre j ai demonter ma ns7 pour avoir les note du vinyl seul mais j arive pas a utiliser midi-ox pourai tu mede stp merci
Posted Wed 08 Jul 09 @ 11:11 am
@cedry
peux tu m'expliquer en plus explicite ton projet ? mais sur le forum francais ou il ya aussi un topic sur la ns7 que je suis avec attention merci . car les moderateur ne veulent pas de francais sur les forums en anglais
http://www.virtualdj.com/forums/111995/French_Forum/Numark_Ns7_et_virtual_DJ_6.html
merci
merci
Posted Wed 08 Jul 09 @ 11:25 am
@tjeck
ok i will see for the xfader leds and and start and stop . but I think that the platters have cc code as : cc="0x00" and cc="0x02"
and the vinyls has others cc code ??? do you think so ?
Posted Wed 08 Jul 09 @ 11:58 am
@ DJmola
I´m back but not down to earth. Sorry.
We´l continue tommorow .
Posted Wed 08 Jul 09 @ 6:12 pm
00 is left and 02 is right (you are correct)
Posted Wed 08 Jul 09 @ 10:19 pm
@dj esco
<fulljog cc="0x00" mask="0x7F00" name="JOG_LEFT" deck="1" full="0x1000"/>
<fulljog cc="0x02" mask="0x7F00" name="JOG_RIGHT" deck="2" full="0x1000"/>
yes this is the right config in def file but only for the platters
Posted Thu 09 Jul 09 @ 4:57 am
OK we will be patient ! I have created this topic in aim to work together on a same map file . not to do differents maps . We need to share our file to progress . all we expect from you is to let us uploading our fle .
thanks for your understanding .
the file is now avalaible on vdj download tool area :
http://www.virtualdj.com/addons/8508/NS7_Def___Mapper.html
Do we have a permanent place to put the updated mapping that is being collaborated on, seems it keeps getting deleted.
How can we obtain the newest mapper?
Posted Sat 11 Jul 09 @ 1:03 am
As already said, we don't delete the file !!!
Posted Sat 11 Jul 09 @ 5:02 am
Mappers are only available to licensed users ...
Posted Sat 11 Jul 09 @ 10:09 am
Alright, sorry about being away for so long. I'm very excited about the progress that has been made.
After playing around with V1.4 of the Mapp and Def files, I've found the following issues (forgive me if these are already known):
Is there anything that I should be looking into?
Regards,
Wesley
- XFADER Reverse :seems to be more of a toggle switch
- FADER START: toggles both decks
- BLEEP: seems to just reverse the deck ( The only way i can play forward again is by playing in reverse :p)
Regards,
Wesley
Posted Sat 11 Jul 09 @ 4:06 pm
Also...I'm not getting any audio coming through when played in reverse.
Anyone else having these issues?
Posted Sat 11 Jul 09 @ 4:07 pm
@sirwesley
Welcome back
Have fixed BLEEP in ver. 1.3.1 but now it will not work. I take a look at this tommorow.
That thing with audio is strange. I can hear it on my system.
Welcome back
Posted Sat 11 Jul 09 @ 4:27 pm
hello ! I'm not in france to work on it !
and what is the probleme with the sound , cause i don't have any probleme with it !
For all users ! this NS7 map is only avalaible for LICENSE USERS on VDJ downlod tools area !
have a good work !
have a good work !
Posted Sun 12 Jul 09 @ 12:45 pm
I´ve have fixed theese problems and send to all of you ver 1.4.1 via e-mail
Posted Sun 12 Jul 09 @ 2:40 pm
