whatever i set the soundcard to, it just resets itself, the 'apply' button is worthless... it just wont let me select the soundcaerd i want to use, I NEED HELP!
Posted Mon 01 Jun 09 @ 12:39 am
it will not work with anything but the onboard soundcard. this should have not been released for mac users. Atomix should have waited took the criticism from the forum and released a better product.
Posted Mon 01 Jun 09 @ 1:07 am
It works fine with my Edirol FA-66.
Posted Mon 01 Jun 09 @ 4:07 am
ok, whilst i understand your gripes here guys.
Mac Version 6 publicBETA - should be the clue here.
It is a beta because there may still be some problems to iron out.
Plesae post your problems here https://virtualdj.com/forums/109660/MAC_Version_Technical_Support/VDJ_mac_version_6_Public_Beta.html
Posted Mon 01 Jun 09 @ 5:20 am
Dan thank for your comments but it does no good to post there if there is no support to that topic. i have seen more Mac forum mod discussion PC issues then mac issues. i understand that its a beta release but come on not working with its dedicated sound card. should have never been released in this shape. my two pennies.
Posted Mon 01 Jun 09 @ 6:28 am
Are you done yet or do you want a to rent a yard sign? Does it work in 5.2? yes then don't take part in the beta session its beta for a reason and yes your issue is noted being pissed off and posting all this negative nonsense isn't helping at all. So why not just uninstall the beta and wait for the official release? 5.2 is the only official release of VDJ on mac.
Posted Mon 01 Jun 09 @ 7:08 am
i have to re-install vdj 5 to switch the soundcard opion, then install 6
Posted Mon 01 Jun 09 @ 3:13 pm
Did that work
Posted Mon 01 Jun 09 @ 10:34 pm
yea... but i have to do it every time
Posted Tue 02 Jun 09 @ 12:29 pm
hey mods can i get a link to v5.2.1 please
DISREGARD
DISREGARD
Posted Wed 03 Jun 09 @ 7:40 am
i have to re-establish my hercules trim 4&6 everytime. cause after i close it w/ this thing attached via usb (and it's the only thing attached to my computer at this pt). it gives me an error. n to report it to apple. but if i dont try n use a soundcard or n e thing input to my computer. it will never hav this issue. n i gotta do this everytime. and a few times to get the thing to work. i know it's not the soundcard cause i can get it to work w/ other programs w/ ease. instead of waiting a few mins to try n tinker around the gui n apply it like ten times to make it work. n then got it to work n the program closes on me a lot when i try n scratch n mix.
Posted Mon 28 Dec 09 @ 1:21 pm
Darknight566:
This is with:
- Which version of VDJ ?
- Which version of OS X ?
Which audio mode are you using on the Trim: 4x4 or 2x6 ?
I know I have some issues with version 6.05 if I'm in 2x6 mode and I try to use Timecode. In 4x4, It seems to work fine.
This is with:
Posted Mon 28 Dec 09 @ 2:51 pm
