why doesnt my vdj respond unless my HD4500 is conneted? if i press play, nothing happens.. i
Posted Sun 31 May 09 @ 9:04 pm
There is a thread dedicated to the beta ... https://virtualdj.com/forums/109660/MAC_Version_Technical_Support/VDJ_mac_version_6_Public_Beta_.html
And to quickly answer your question ... Go check your Mac's Audio properties and make sure the internal soundcard is set as the Built-in Output.
Posted Sun 31 May 09 @ 11:20 pm
it is...
Posted Sun 31 May 09 @ 11:33 pm
problem really isnt solved, but i got it to work.. but i had to install vdj5 and then reinstall6...the problem might have been that my first time using it, it was hooked up to the controller.. i dont know
Posted Mon 01 Jun 09 @ 12:01 am
now i cant use my midi soundcard.. it keeps switching back to 'built in output'
this is pretty frustrating.. when i set the soundcard to a different output it just resets itself.. the apply button is worthless
Posted Mon 01 Jun 09 @ 12:05 am
