New MAC Driver for Snow Leopard
Hercules MK2 - MP3 - MP3 e2 - RMX - Steel - Trim 4&6 -> MAC OS X 10.4 (Tiger) - 10.5 (Leopard) - 10.6 (Snow Leopard) / v1.73
ftp://ftp.hercules.com/pub/webupdate/DJCSeries/DJSeriesInstall_1_73.pkg.zip
- OS X 10.6 (Snow Leopard) support.
- Support for DJ Control MP3 e2
- Firmware updater redesign.
- Minor bug fixes.
- Minor bug fixes.
Posted Fri 18 Sep 09 @ 3:43 am
I have heard that the RMX offers 16 bit sound by default as well as 24, but with some constraints. Can anyone describe if that is true or if there are issues with the 24 bit mode? Curious as to why a "professional" DJ Console would offer a 16 bit option?
Posted Fri 18 Sep 09 @ 10:59 pm
Now it's time to share my problem.
Yesterday i purchased the RMX console. I wanted the sound to go through my compute. I connected the red and white outputs (1,2) to the microphone input on my soundcard, no sound (I made sure the microphone was on in the settings) I don't know how to do it. The only way I found is conecting through the headpones output on the console, But I want to use the headphones too, so please help me.
Posted Sat 19 Sep 09 @ 2:33 am
Hello keyvee,
You must connect your speakers, headphones and microphone on your DJ Console Rmx plugs:
- connect the amplified speakers to DJ Console Rmx output 1-2
- connect your headphones to DJ Console Rmx headphones output (on top or front panel of the Rmx)
- connect your microphone to DJ Console Rmx microphone input (on top or front panel of the Rmx)
Your computer microphone input has not the same impedance as a line input, so it is not surprising you don't hear much (or maybe nothing) when you connect your DJ Console Rmx output 1-2 in your microphone input.
Posted Sun 20 Sep 09 @ 4:37 pm
Hi everyone,
I went to a club to audition tonight and had a nightmare, basically I've switched back to my Hercules mk2 after my RMX broke and I couldn't get it to work properly.
I would have a track playing and when I pressed play on the other side the one that was playing live stopped! my setting were:
Sound Setup
None
Headphones
4.1
Master Rear out/Headphones: front output
Hercules mk2
Mappers
Hercules Mk2
DJ Console Mk2 Panel/Main
Output Channels/Computer Screens
Input Channels/The second box was selected (Image of a Jack plug)
Audio Mode/WDM
Could you tell me what it should be, Im using it off a channel on the main mixer and have my headphones pluged into the mk2. Basically not using the main mixer at all.
I'm using the latest VDJ 6.02 and have the 2009_HDJS_2 Hercules driver installed.
My PC spec is: 2.2Ghz dual core, 256mb, 4gb, 500gb, Vista Premium
Charlie
Sound Setup
None
Headphones
4.1
Hercules mk2
Mappers
Hercules Mk2
Audio Mode/WDM
Charlie
Posted Sat 26 Sep 09 @ 4:41 pm
Basic Question I am using Vdj Console edition
On Deck B when i spin the track forward i hear sound , but when i back spin on Deck b I hear no sound is there a fix for this? Deck A works fine when i back spin or forward spin i hear sound
Posted Sat 26 Sep 09 @ 10:06 pm
Can't help you with MK2 setup I'm afraid, but just so you know, there's a later Herc driver package (2009_HDJS_3).
Posted Sat 26 Sep 09 @ 10:08 pm
ok I tried to see if i could fix my problem but now on both decks
both deck a and b when i spin forward i hear sound but when backspinning i hear no sound
I am using vdj le console edition, please note deck a was working earlier when back spiinning and forward spiining with sound., i dont think its a hardware issue but im not an expert with this piece, please le t me know
Posted Sat 26 Sep 09 @ 10:40 pm
Thanks Mga,
I'll get it now, hopfully with the help of others I'll get it sorted
Posted Sun 27 Sep 09 @ 4:21 am
Here my new Hercules MP3 e2 video, in Italian language but with English subtitle ;)
http://www.youtube.com/watch?v=8xNnEqq75wQ
Posted Mon 28 Sep 09 @ 5:14 pm
