Forum: Old versions
Topic: Need help setting up equipment
I have just purchased 2 Pioneer CDJ800 MK1. I want to run Virtual Dj from my laptop. How would I go up setting this up? Several people I have talked to have told me this isn't possible because the turntable doesn't have USB ports on it, so I would have no way to send the MP3 signal playing from my laptop to the turntables. I would like to get the opinion of this community..thanks! I have heard about USB soundcards like the Maya44..is this something I would need?
Posted Fri 17 Apr 09 @ 7:32 pm
I am not positive if you can reach this link without being registered but it contains the info you need.
https://virtualdj.com/wiki/
Look at the timecode and soundcard manuals listed there and it will explain how you can set up. You do not need usb ports on your hardware but you do need a 4 input 4 output soundcard.
