Hi I was just wondering if VDJ supports 3-4 turntables using TCV. I know the soundcard would need at least 4 line ins and outs to make this possible although it would be nice. I have always loved to have a 3rd table for extra effects or beat juggling while mixing in a song.
the looping features on VDJ is great although I'm sure takes a bit more out of your system when using it. plus it looks much better when the DJ looks more active at work LOL.
If this feature is not supported I would love to see it as an option maybe in later versions
Thanks
DJ White Devil
Thanks
DJ White Devil
Posted Sat 12 Mar 05 @ 12:27 am
I'm not sure but if you open 2 instances of virtual Dj i think it's possible
Posted Sat 12 Mar 05 @ 2:15 am
either that or have 2 laptops with VDJ running probably
Posted Sat 12 Mar 05 @ 2:24 am
and you can even have them synced over network :)
Posted Sun 13 Mar 05 @ 8:03 pm
With 2 computers or only one , you can use 2 instances of Virtual DJ. If you use only one,your computer has to be powerfull with a lot of memory
Posted Sun 13 Mar 05 @ 8:19 pm
