Forum: Old versions
Topic: Midi controllers and sound settings
Hi Guys!!!
Ok here is this weeks problem...... I work in a club where they have just installed 2 nice new shinny cdj400!!!! I know that I can plug these units directly into my lapy (macbook white) but :
1/ which sound setting do I need
2/ how do I set the midi on the cdj to midi 2
then I want to use my denon 2500 for other clubs, the problem I'm having with this one is the same again
1/ which sound setting do i need
all i seem to be getting out of the denon is 1 channel in split mono (so deck 1 is playing deck 1 audio from left and deck 2 from right)
any help would be great and I think what would be better is if you had an idiot guide on this sit somewhere to tell us how to set these things up like a page for each controller.
p.s. still waiting for the Karaoke rotation plug-in for the mac version...... thinking that I should of bought pcdj and a windows machine
thank for your help
Posted Sat 14 Mar 09 @ 5:55 am
I take it that no body has the links or actually knows what the setting should be with a mac then?????????
Not having one of these myself i coudlnt categorically say but i would think you will need some kind of split out and then select the CDJ soundcards.
This may help: https://virtualdj.com/forums/104602/MAC_Version_Technical_Support/Mac_version_And_%3Cspan%20style=
(or not as the case maybe)
I too am still waiting for this. Apparently it isnt as simple as you may think to port the app to Mac. As it required DirectX which is Windows based. I hope they are working on a Mac equivalent of this and the "Titler" plugin.
Thanks for your help fella!!!!!!! Very much needed
But have just noticed that the thread you posted wasn't for getting them working in version 6
Ta Anyway
