Topic: need more sampels
co0ldjPRO InfinityMember since 2003
can u plz make some co0l samples to play other than the origenal booring one's
and if u or the compeny can make new ones tell me where i can find them
DJ SOUL HACKER
Posted Sat 02 Aug 03 @ 12:46 pm
can some one anwser me plz
Posted Sat 02 Aug 03 @ 1:07 pm
i have many songs
i have
english songs (they apear in a known font ) like the song name is pop it apears pop
frensh songs same
but arabic songs they apears in an unknown font like the name of the song is writen i arabic font which is known in my com. they wil be like ÍÈíÈí i don't know if u had seen it well
i can't see the name of it in the vdj so can u help me
Posted Sat 02 Aug 03 @ 1:16 pm
DJ CocoPRO InfinityMember since 2003
you need to change the language xml and select a valid arabic font..Since i don`t speak arabian, i cannot help you..sorry..
Posted Sat 02 Aug 03 @ 11:20 pm
sorry but can u plz enter to the chat room i need to talk with u
Posted Sun 03 Aug 03 @ 11:00 pm
dj_samoHome userMember since 2003
Dear Cool dj
i am from lebanon and i can to help you coz i speak the arabic lang.
this problem that you have now, i was having it from the Atomixmp3, & from many mixer programes software...
But if you like to know what the name song to play it, you must to rename the song ex: sa7arni / najwa karam ...
and when you pot it on the atomixpm3 or at VDJ, the programe will type it like you type : sa7arni / najwa karam .
that is all
D.J Samo from Lebanon
Posted Tue 05 Aug 03 @ 8:51 pm
you can use a program called BPM 4,0 to make sampels..
there you can make the "samples" just like you want them,
it's very easy to use..!!!
you can make sampels from your harddrive or from a CD and save them, and then use them in virtual dj..
i use this program to make all my sampels.
Anders Skoog
Posted Thu 07 Aug 03 @ 10:55 pm
Anders Skoog
You say that the BPM 3.0 or 4.0 version make sampels that yes.
but you can make the pro. samlers from "cool edit or sound forge... " and many software but with this programes you can make with the samplers :
1- Flash.
2- Loop.
3- Turn table.
4- Play back .
5- you can play Bitch in any part of the sampler.
6 -and more ...
sorry about my english
REGURDS
DJ_Samo from Lebanon :)
Posted Sat 09 Aug 03 @ 9:09 pm
