Anyone there?
Posted Tue 24 Mar 09 @ 1:05 pm
can someone just tell me if it´s possible to config,deck´s volume levels coming from gain?
Posted Tue 21 Apr 09 @ 12:32 pm
Hi,
Quick quection musicalcheers, I want to get a midi interface for my DJM 700 and you mentioned you have a Edirol UM that works fine with it. I can't find this online anywhere, only the UM-1EX, do you know if there is anydifference between the two that should limit its use with the mixer?
Thanx in advance
Thanx in advance
Posted Wed 13 May 09 @ 11:03 am
Pretty sure mine is a UM-1 as well mate but the rig is all packed up in the van at the moment. I will have a look after work tonight though and let you know for sure.
Posted Wed 13 May 09 @ 2:09 pm
I use a djm800 and I don't think you should have a prob with the edirol um-1ex but can't promise for sure. I use M-Audio midisport 2x2 and have never had a problem. I got a 2x2 in case I needed an extra midiport down the track. I've never needed it tho.
Posted Wed 13 May 09 @ 7:34 pm
Can confirm mine is UM-1ex Sorry must have been a bit lazy writing the model numbers ;)
Works well with my pc. Instant midi comms and never had a problem either. Can also confirm the m audio stuff is good too - I use one of their other interfaces on my studio pc.
Posted Thu 14 May 09 @ 12:06 am
Nice one for the help you two!
Gonna get one of the two sorted today, just need to see if the 2x2 cost that much more.
Nice one again!
Nice one again!
Posted Thu 14 May 09 @ 4:10 am
Looks like the Anzac connection shines through, hehehe!
Posted Thu 14 May 09 @ 9:28 am
hehe - nice!! Where in Aus are you Bish?
Posted Thu 14 May 09 @ 3:35 pm
