If so can you post your soundcard and settings - my Herc Mk2 with Technics keep having issues
Thanks
Thanks
Posted Tue 10 Feb 09 @ 9:00 pm
Posted Wed 11 Feb 09 @ 2:31 am
They have deleted your blog!!!
So your set up does actually work? Are you using Technics 1210s? What cartidges? I keep loosing audio Timecode quality now. I have brand new stanton cartridges and styluses and TCV. -- :-(
Posted Wed 11 Feb 09 @ 8:34 pm
I found Digi Tracks from Ortofon give the best results with the MK2.
Posted Thu 12 Feb 09 @ 4:32 am
I can't make the TCV work with my maya 44 usb neither...
The signal is not stable, and the sound driver stops working after 10min. No more tcv control, or a very big latency...
I can't use this system to play in public for the moment...
Posted Fri 13 Feb 09 @ 9:35 am
My blog it's not deleted, check it please.
I use Gemini PT-2100 turntables, Ortofon Concorde DJ S styluses and VDJ TCVs, and works fine in Hercules Consoles.
Posted Sat 14 Feb 09 @ 6:42 am
I have got the ortofon qbert the hercules mk2 and vdj on a mac.
I am using the serato vinyls but I also have used the vv tc vinyls.
Everything is workin perfect without any bugs.
But one question:
So it is not possible to work with an audio 8 dj on a mac? because i wanted to buy one next week ;-0
sEe yA
But one question:
sEe yA
Posted Sat 14 Feb 09 @ 10:49 am
@marcusr, check xonor blog link here;)
https://virtualdj.com/homepage/xonor/blogs/3319/VDJ___Hercules_MK2___TCVs_(Mac_OS_X).html
Posted Sat 14 Feb 09 @ 1:47 pm
THe links to the Time Code setups have been deleated, does somebody have another link? I am having troubles using my MK2 with a time code setup. I have everything setup properly I think. Inputs I have: channels 1-2 left deck and channels 3-4 rights deck (I get 100% Time code signal and I can see the mp3 files being controlled in VDJ)
BUT.........
The output is my problem, the song from from deck A plays on outgoing channels 1-2 and also on 3-4
Im using the MK2 as a soundcard with an external mixer
BUT.........
Posted Wed 12 Aug 09 @ 11:19 pm
Hi.. It is still there..
Please do log in to the site before you click on the link.
Regards;)
Regards;)
Posted Thu 13 Aug 09 @ 6:32 am
I'm using Numark TTX's with otrofon digital cartridges (not the concords) with SSL v2 colored vinyl (blue and red) with a Maya 44 USB. Works flawlessly for me. Works on beta but not on v5. OS X v 10.5.6.
Posted Sat 15 Aug 09 @ 6:26 pm
BUT.........
BUT.........
In the audio setup up have you selected external mixer from the drop down? Do you have left channel set up with 1&2 and right channel setup with 3&4?
Posted Sat 15 Aug 09 @ 6:28 pm
When I'm using vinyl instead of my CDJ's I have to boost my signal to max on the input. What turntables are you using? My Numark TTX's have a line out instead of a phono which provides for a stronger signal If you have this option I would use it.
Posted Sat 15 Aug 09 @ 6:31 pm
