Forum: VirtualDJ Plugins
Topic: Problem with GetInfo (MAC)
k090PRO InfinityMember since 2006
I have a stupid problem I can't resolve.
char string1[128];
char string2[128];
char *Filename;
int Status;
Filename = NULL;
GetInfo("FileName", &Filename);
GetInfo("Status", &Status);
wsprintf (string1, "Filename: %s", Filename);
wsprintf (string2, "Status: %d", Status);
My problem is that plugin crash when get Filename.
If I change command to
GetInfo("FileName", Filename);
I always receive (null).
I don't know where I make a mistake. I have no problem to get Status. Its similar but doesn't work :(
Posted Mon 09 Feb 09 @ 5:33 pm
djcelPRO InfinityModeratorMember since 2004
You have to allocate your pointer. You can use a buffer of 512 char if you are not sure.
Posted Tue 10 Feb 09 @ 1:41 am
Thanks, it works.
Posted Tue 10 Feb 09 @ 3:12 am
