i have my cdj (denon 3000) hooked up to my maya44 and then plugged into my 2ch. mixer
but is it possible?????????
to play my regular cd's when my computer is off or not plugged in
or
do i have to unplugging my wires from my maya44 and then plugged them into the mixer and when im done i have to switch back to the maya44
i know how to use the bypass when the computer is ON, but i dont have my laptop with me that much, and i dont want to unplugged the maya44 and then plug the wires into the mixer and when i want to use my laptop i have to switch the wires back
help please
or
help please
Posted Tue 22 Feb 05 @ 4:49 am
Try this setup
https://virtualdj.com/blog/Dams/blog738.html
PJay
PJay
Posted Tue 22 Feb 05 @ 6:27 pm
actually i dont think that setup will work for you as you probably wont have 4 line inputs on your mixer
if it was normal turntables then you use 2 line ins and 2 phono ins
only other way round would be to get a mixer with 4 line ins
PJay
PJay
Posted Tue 22 Feb 05 @ 6:39 pm
most 2 channel mixers have 2 x line in AND 2 x phono in
one set of inputs for each channel
Posted Thu 24 Feb 05 @ 12:04 pm
thats true but he needs 4x line ins i think . hes not using turntables
Posted Thu 24 Feb 05 @ 7:02 pm
That's true I have 2line and 2 phono,
So I do need more lines
Now if I was using turntables I do the same thing
Right
Thanks a lot
I might get the pioneer djm 500
Right
Thanks a lot
Posted Fri 25 Feb 05 @ 10:49 pm
