Forum: Old versions
Topic: SCRATCHING ON VIRTUAL D.J PRO 5.2.1 - Page: 1
HELLO CAN SOME 1 PLEASE HELP ME
I GOT THE HERCULES RMX AND VIRTUAL D.J PRO 5.2.1 A FEW DAYS AGO
BUT I HAVE NOTICED THAT THE SCTATCHING IS NOT LIKE A VINYL OR WHEN SCRATCHING ON A CDJ
IS THERE ANY WAY I CAN MAKE THIS SOUND LIKE THE REAL DEAL SCRATCHING
I AM LOOKING FOR THAT VINYL SCRATCH SOUND
SOME 1 PLEASE HELP PLZ PLZ PLZ
EMAIL ME PLZ I HAVE A GIG COMEING UP IN A FEW DAYS
Ur contact i moved to the post by me and pls no caps;) - spinna
Posted Wed 14 Jan 09 @ 9:47 pm
yo i was told it really cant be done because there isnt a way to make the jogwheel freeze as if it where on a real turn table.
so there is no way i can get the real scratching sound.
what if i use my cdj and the time coded cd
then will it work right
can some 1 please tell me what i need to do
i am looking for that real scratching sound
i cant send the product back so now i have to make this work can some 1 help me
i am looking for the real scratching sound
but this hercules rmx and virtual d.j pro 5.2.1 dont give me that sound
Hi dj swagga, to scratch like a real turntable is not 100 percent possible as it is not touch sensitive jogwheel. Butt u can try.
The bestl solution for it is to use timecode route via a TT.
Hope this helps;)
hi and thanks
but what is a timecode route via a TT
It using the timecode vinyl (TCV) with turntable etc...hehe;)
so if i want that sound i need a cdj that go with the program
will i need that black box also
i am new to the d.j world also
He said that he put the belt between the big wheels and the small wheels.
It sounds better, but......still can't do some scratch mixing trick.
Like holding the music with finger touch, release and go.
between what big wheels and small wheels>>
also i have another question
when i have moveing my faders or volume or any button on the rmx console
i am hearing a stattic noise like something needs to be grounded can some 1 plz help me out here i cant do no gigs untill i fix this
hercules to me to go by some other thing to go with it
"like money is growing on trees right now in a "recession"!!!!
hi
i have all my problems fixed now as far as i can hear
now i need help finding out what is the best way to go
should i just go by a cdj that go with the rmx console and use the time coded cd
or what is the best way to go
plzsome 1 reply asap
thanks
also if useing the timeceded cd is that all i will need just the downloaded cd
Hi swagga,
I think you have three solution right now.
The clip you posted, which doesn't act like a real vinyl.
He hooks up belt between jogwheel on RMX and his DIY pad, and then it become a simple mechanism like bicycle.
The big pad itself doesn't spin. It just make the jogwheel bigger and easy for scratching.
The first solution is the CDJ solution. Of course you need a touch sensitive CDJ and timecode CD then you can do actually scratching.
The second solution is the turntable solution, for this you need 2 TTs and 2 TC Vinyl.
The last one is the most expensive one. Wait for Numark NS7. You can check this thread.
https://virtualdj.com/forums/103566/Hardware_Technical_Support/Why_not_Turntable_Controller___.html
I am still looking for RMX scratch solution, and right now I think the 2 TTs' solution will be easier and cheaper for me.
Anyway, the NS7 is fantastic. I really would like to try it if I had a chance.
Forgot to mension.
NS7 is not actually a RMX solution. It's a new controller, but it's fully digitaled.
Imagine you got 2 TTs and mixer in one controller and it actually spins like real vinyl.
so if i go cdj i will only need the downloaded time coded cd
I think yes.
The only thing you need to do is download and burn the TCCD if you already have CDJ.
After you try it, could you tell me how do you feel about the CDJ scratching with RMX?
you have never tryed it
if not do you think the words will match up right
Well....
That's the reason I said I think yes.
I did some research on this forum, and answer you according to the post here.
If it's not correct, I hope that there are others would come to point me out.
Sorry if I mislead you.
95%
