dj-in-norway wrote :
Let me try to recap a little...
1) When playing on your Denons, its timecode right, that is used to control VDJ?
2) What do you mean by playing in VDJ then? Playing without using the Denon as timecode controller?
And as for the knobs and all to work, you have to enable midi, and map them up in VDJ, or use a premade mapper... (if one is made)
Hey Norway... I was unable to use the high, mid and bass knobs... (that problem is resolved) i restored the mixer back to factory settings...
I have no more problems with the TIMECodes.. SBDJ sorted that out for me....
My Problem is... Rite now running VDJ this is the layout of my settings rite now in CONFIG (section of VDJ)
INPUTS ---> None
OUTPUTS ----> 3 Lines Mixer
SOUNDCARD ----> Asio Driver
ASIO DRIVER ---> Ecler EVO Asio driver (there is also a box that says Ultra Latency ASIO, i checked it)
PROBLEM... I am able to hear what is being played through the main output (of the active deck).. for some reason I can't hear the other deck through my headphone...
The problem is not there if I was to use my HS5500.. everything works normally....
any suggestions..
Posted Fri 16 Jan 09 @ 9:17 am
Sounds about right, should work, I use this setup live several times a week. I'll verify though and get back to you :)
Posted Fri 16 Jan 09 @ 9:19 am
thank you SBDJ
Posted Fri 16 Jan 09 @ 10:07 am
is this mixer compatible with vistas 64 bit??
Posted Fri 16 Jan 09 @ 10:27 am
I am not certain... my OS is XP.. SBDJ or Norway should be able to assist u with that bit of info...
Posted Fri 16 Jan 09 @ 10:41 am
There are no 64-bit drivers for the Ecler Evo 5 I'm afraid.
Posted Fri 16 Jan 09 @ 2:44 pm
Posted Fri 16 Jan 09 @ 2:53 pm
I know... it's certainly a shame. DJ vendors seem to be taking their time in general with x64 drivers.
Posted Fri 16 Jan 09 @ 3:14 pm
sbdj have u any suggestions y i can't monitor my decks through the headphones?
Posted Fri 16 Jan 09 @ 3:41 pm
Could someone post the best setting for good latency and sound quality it seems like I have to give up one or the other.
Posted Sat 17 Jan 09 @ 9:19 am
If anyone needs help with evo 5 contact me..I have mappings and settings for vdj and evo 5. I use channels 1 and 4 for tc with the dennon 3500's. if your wanting to use any channels besides 1 &2 for tc you will have to make some registry settings within VirtualDJ.
Posted Sat 17 Jan 09 @ 9:56 am
Hey FunnyB0nz... I could do with some help.. whats ur contact info?..
Posted Sat 17 Jan 09 @ 11:58 am
SOS
Posted Sun 18 Jan 09 @ 8:29 am
SOS SOS
Posted Mon 19 Jan 09 @ 3:45 pm
Try to send him PM ;)
Posted Mon 19 Jan 09 @ 3:53 pm
Sorry, not had a chance to get my Evo out yet, will see if I can get some time tomorrow evening...
Posted Mon 19 Jan 09 @ 4:45 pm
swizzle....check your PM. I am getting my vdj config and evo 5 config and emailing out. Like I indicated I use my evo as follows channel 1&4 is timecode. channel 2 I use the volume up and down fader for video fading (nice to have it seperate) and use channel 3 for pc sound (effects withing vdj). I do not like channels 1 &2 for time code because so close together and not good for scratching. However the way I do it, you will need to make some registry changes on your pc under virtual dj portion.
Posted Mon 19 Jan 09 @ 5:16 pm
DJ-In-Norway......Hey if I send you these you want to post them on the site for fellow users to download? I have some nice settings that allow you to switch modes on deck, also to allow you to use your cd players normal while using timecode on a channel.
Posted Mon 19 Jan 09 @ 5:18 pm
thats a good suggestion
Posted Mon 19 Jan 09 @ 8:13 pm
sounds like a plan... i hope you di.. thanks alot..
Posted Mon 19 Jan 09 @ 8:14 pm
