Hello mates.
How can i connect two laptops with a lan conection, and what are the settings???
Have done almost everything nothing hapends!!!
Pls help if somoene know what to do!!!
Regards.
Regards.
Posted Tue 08 Feb 05 @ 9:08 pm
first of all how are you connecting the 2 laptops?
through a hub or router or directly from 1 laptop to another?
if you are connecting the 2 laptops directly from one to another you will need to make sure you have a crossover RJ-45 cable (network cable) and run the configuration
Here is a site with information on how to setup a home or small office network that should give you some basic information.
http://www.pcworld.com/howto/article/0,aid,68763,00.asp
if you keep having problems after doing these steps post again with more information as to how your network is setup and I can help you out a lot more.
Best regards
DJ White Devil
Best regards
DJ White Devil
Posted Tue 08 Feb 05 @ 10:22 pm
I have already conect the two laps together (have already share files between them), but i don't know the settings in the configuration, in VDJ, so that the are can playing together (sync, beatmatch, etc.etc.)
THNK AGAIN
THNK AGAIN
Posted Tue 08 Feb 05 @ 10:35 pm
Oh as far as that goes I don't think its possible although I'm sure someone with more experience with VDJ would be in a better position to answer that.
Best regards
DJ White Devil
Best regards
DJ White Devil
Posted Tue 08 Feb 05 @ 11:00 pm
Thnx anyway for your try!!
And remember you won't be disapointed when you finaly purchase the full version of VDJ.
You can't imagine what "power" is hidden in this prog.
Best regards. ;)
Best regards. ;)
Posted Tue 08 Feb 05 @ 11:10 pm
Go into the settings -> network
enter the adresse ip of your computer or the name you gave to them. After that choose the kind of synchronysation an finally restart vdj
To synchronyse the vdj, use the beatlock
Posted Tue 08 Feb 05 @ 11:18 pm
Thnx. I try this.
Regards.
Regards.
Posted Tue 08 Feb 05 @ 11:23 pm
You're welcome
Posted Tue 08 Feb 05 @ 11:25 pm
