Topic: DDJ-REV5: Headphone Mix/Volume balance issue (Cue vs. Master)
Hi everyone,
I'm experiencing an issue with the headphone mix behavior on my Pioneer DDJ-REV5 in VirtualDJ.
While I can cleanly switch and blend between Cue and Master, the Master signal is disproportionately loud compared to the individual cue channel. Because of this massive imbalance, the hardware mix knob has to stay all the way down around the 9 o'clock position to get a usable split.
What I have tried so far:
Mapped isolated commands directly via headphone_volume and headphone_mix.
Removed conflicting parameters like headphone_crossfader from the PHONES_CUE assignment.
Adjusted the internal headphoneGain value down to 0.6 (which improved the situation slightly, but still forces the physical knob to sit abnormally low at 9 o'clock).
Is there a known setting, audio routing tweak, or mapping parameter in VDJ to balance the hardware headphone gain/mix curve properly on the REV5? Any advice would be greatly appreciated!
Posted Wed 04 Nov 26 @ 4:48 pm
