I'm using a RANE ONE MKII with the default VirtualDJ mapping.
When I press the Stop button on the deck, I expect to hear the classic SL-1200-style brake effect. However, the brake sound only seems to work under certain conditions.
If I have any stem active (Vocals, Drums, Bass, Instruments, or a soloed stem), the expected turntable brake effect does not behave as I would expect. I would like the SL-1200 brake sound to be heard regardless of which stem is active or soloed.
Is this the intended behavior, or am I missing a setting or configuration option? I'm using the default mapping for the RANE ONE MKII and have not made any custom modifications.
Thank you for your help.
Posted Wed 03 Jun 26 @ 5:08 am
djcrossfade1200 wrote :
it fixed itself i dont know how so plz lock this ty i just went to my windows 10 and it works there
Posted Wed 03 Jun 26 @ 7:15 am
If the only thing that has changed is a downgrade of Windows version (same VirtualDJ version and settings are being used throughout), then you might want to take a loom at the following thread (and the many others on the Windows updates affecting controllers issue):
https://virtualdj.com/forums/269000/VirtualDJ_Technical_Support/Win_11_Advice_please.html
Posted Wed 03 Jun 26 @ 11:37 am
ty vinyltouch
Posted Wed 03 Jun 26 @ 12:56 pm
