Topic: Denon SC6000 Engine OS 4.2.0 - Loading tracks not working properly
Hello,
I use VDJ on a Macbook Air M2 (Mac OS Sequoia 15.3.1) with SC6000s (Engine OS 4.2.0) and when I try to load a track by pressing the browse encoder most of the time it will not work on the first press but I need to press multiple times. Everything else seems to work as usual.I think this problem started after updating to Enigne OS 4.2.0. Any help would be greatly appreciated.
Posted Thu 13 Mar 25 @ 6:03 pm
By multiple times, you mean 2 or more ?
Perhaps Deck was playing at that time, and you got some Load Security Warning window on the main skin which requires an additional press ?
Yes, 2-4 times, it‘s really inconsistent. There is nothing playing. It already happens on the very first song you load after starting vdj. I‘ve been using vdj and the sc6000s for years and never had this behavior.
